Just completed tests with latest (and last) basic Keyboard (EN014) using my Keyboard Development Module version 2.0 and everything worked perfectly including the RGB.
The EN014 Keyboard differs only in the 1) position of rotary encoder moved to left of the Print key allowing for 2) better spacing of function keys and 3) moving of the Caps Lock Led to top side of PCB (beside the caps lock key).
The EN014 board was tested with version 2.0 of the keyboard development module (34 pin connector), basically both boards and the code were validates, as was the new keyboard plate...
Mike
Michael O'Toole
