Version D
A project log for Keyboard Development Module (QMK-VIA)
RP2040 Modules Board for QMK and VIA Keyboard Software Development
michael-otooleMichael O'Toole • 12/17/2025 at 13:46•0 Comments
In version C, the IDC connector had to be mounted to bottom of PCB (I screwed up the orientation)...It work perfectly but I would prefer all components on the same side (aesthetic/logical), so to Version D.
Version 2.0D has been tested and works perfectly, once again, thanks to PCBWay for the fabrication.
As to a keyboard, you can use my Basic Keyboard design (hand assembled, just need PCB and parts), or you can design your own, be it a keypad, macro pad or full sized keyboard...
The important point is you don't have to design the logic, just use the Keyboard Module and you are QMK/VIA ready. Just change my code to suit your needs...
See my git for example code here: EN14
Notes:
If your wondering how you can test your code, I include a breakout / breadboard friendly converter PCB here... (includes link to Gerber Files and KiCad Files)
Mike
