25/10: I created a connection between two parts with 2 ball bearings and a shaft but at the end I realized that it will not be possible to be hand directed because of the bearings on the part that is supposed to move. The solution turned out to be the use of a coupling instead of the ball bearing. It has to be fixed on the shaft and on the moving part.
