Hackaday.io Hackaday.io
Sign up Log in
LED Maze Solver
An LED maze solver using the Arduino microcontroller and MAX7219 LED driver
sebastian-jimenezSebastian Jimenez
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
86
0
0
1
Team (1)
  • sebastian-jimenezSebastian Jimenez
Join this project's team
  • Source Code
  • Video
hardware
completed project
arduino led max7219 MAZE Pathfinding
This project was created on 10/14/2024 and last updated 2 years ago.
Description
I designed and built an LED maze solver using an Arduino microcontroller, which generates a random maze and solves it using the A* pathfinding algorithm. The maze is solved almost instantly in each iteration, with a dot visually tracing the solution on the LED display.
Details
Log In/Sign up to comment
Sign up with Github
OR
Circular LED lamp
Project Owner Contributor
LED LAMP
julienJulien
Arduino library for driving hundreds to thousands of WS2811, WS2812 or INK1002 addressable RGB LEDs.
OctoWS2811 LED Library
paul-stoffregenPaul Stoffregen
I will get back to this! Haha it works I promise!
LED CUBE WITH ARDUINO UNO
davidDavid
LED Matrix using Pixel Blaze
LED Box
morganmorgan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "LED Maze Solver", please tell us the reason.
Send message
Remove Member
