There are two methods I can see for attaching add-on diffusers to blink(1):
* mount directly to PCBA
* mount to metal frame (that carries PCBA)
I was initially designing for the former, but I think it will be structurally stronger (and safer for the PCBA) if I design for the latter.
I've uploaded several attempts at PCBA-mounted sconces. They work... sorta.
Things I like about some of the designs, even with the bad mounting technique:
* the circular arc diffuser is minimally classic
* two of the designs have inserts for a message to help define what the blink(1) is for (see the "NO NO NO") in one of the photos
