I needed to port my Arduino design onto the RP2040. I was going to use a boost converter, but I don't have one, so I just decided to use the 5V rail on the RP2040-One that gets "populated" on the RP2040 when powered over USB. If I take care of the 5V rail on the circuit later, the code should be the same either way.
We can see I have another rp2040 "SAO" connected via a directly soldered I2C bus ;) I'm working on the I2C communication -- the disconnected rp2040-Matrix you see connected will be pretending to be the conference badge (the I2C master), for now.
Pics of the updated prototype circuit:
A video of the same animations playing, but now through micropython:
The ported code is as follows:
# Arduino code ported to RP2040 micropython
import machine
import neopixel
import time
import random
LED_PIN = 8
LED_COUNT = 14
LED_BRIGHTNESS = 0.05 # Start with 0.1 to check visibility; adjust to preferred level
LED_CENTER_LEFT = 0
LED_CENTER_RIGHT = 7
LED_LEFT_MIN = 1 # Exclude center LED (left spool)
LED_LEFT_MAX = 6 # Exclude center LED (left spool)
LED_RIGHT_MIN = 8 # Exclude center LED (right spool)
LED_RIGHT_MAX = 13 # Exclude center LED (right spool)
# Initialize NeoPixel
np = neopixel.NeoPixel(machine.Pin(LED_PIN), LED_COUNT)
LED_LEFT_INDEX = random.randint(LED_LEFT_MIN, LED_LEFT_MAX)
LED_RIGHT_INDEX = random.randint(LED_RIGHT_MIN, LED_RIGHT_MAX)
# Original colors
FOREGROUND_COLOR = (0, 0, 0) # Black
BACKGROUND_COLOR = (255, 165, 0) # Orange
CENTER_COLOR = (255, 0, 0) # Red
# Function to adjust brightness with minimum scaling effect
def set_neopixel_color(color, brightness_factor):
return tuple(max(int(c * brightness_factor), 1) for c in color)
# Animation functions with brightness adjustment
def animation_play(millis_delay=130):
global LED_LEFT_INDEX, LED_RIGHT_INDEX
# Play animation for left spool
if LED_LEFT_INDEX < LED_LEFT_MAX:
np[LED_LEFT_INDEX] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np[LED_LEFT_INDEX + 1] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_LEFT_INDEX += 1
else:
np[LED_LEFT_MAX] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np[LED_LEFT_MIN] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_LEFT_INDEX = LED_LEFT_MIN
# Play animation for right spool
if LED_RIGHT_INDEX < LED_RIGHT_MAX:
np[LED_RIGHT_INDEX] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np[LED_RIGHT_INDEX + 1] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_RIGHT_INDEX += 1
else:
np[LED_RIGHT_MAX] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np[LED_RIGHT_MIN] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_RIGHT_INDEX = LED_RIGHT_MIN
np.write()
time.sleep_ms(millis_delay)
def animation_rewind(millis_delay=50):
# Rewind animation for left spool
if LED_LEFT_INDEX > LED_LEFT_MIN:
np[LED_LEFT_INDEX - 1] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_LEFT_INDEX -= 1
else:
np[LED_LEFT_MIN] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np[LED_LEFT_MAX] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_LEFT_INDEX = LED_LEFT_MAX
# Rewind animation for right spool
if LED_RIGHT_INDEX > LED_RIGHT_MIN:
np[LED_RIGHT_INDEX - 1] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_RIGHT_INDEX -= 1
else:
np[LED_RIGHT_MIN] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np[LED_RIGHT_MAX] = set_neopixel_color(FOREGROUND_COLOR, LED_BRIGHTNESS)
LED_RIGHT_INDEX = LED_RIGHT_MAX
np.write()
# Blink to indicate function triggered
def animation_function_triggered(color):
np[LED_CENTER_LEFT] = set_neopixel_color(color, LED_BRIGHTNESS)
np[LED_CENTER_RIGHT] = set_neopixel_color(color, LED_BRIGHTNESS)
np.write()
time.sleep_ms(100)
np[LED_CENTER_LEFT] = set_neopixel_color((0, 0, 0), LED_BRIGHTNESS)
np[LED_CENTER_RIGHT] = set_neopixel_color((0, 0, 0), LED_BRIGHTNESS)
np.write()
def animation_pause():
np.write()
time.sleep_ms(100)
def animation_bootup():
# Illuminate left spool
for i in range(LED_LEFT_MIN, LED_LEFT_MAX + 1):
if i == LED_CENTER_LEFT:
continue
np[i] = set_neopixel_color(BACKGROUND_COLOR, LED_BRIGHTNESS)
np.write()
time.sleep_ms(50)
# Illuminate right spool
for i in range(LED_RIGHT_MIN, LED_RIGHT_MAX + 1):
if i == LED_CENTER_RIGHT:
continue
np.write()
time.sleep_ms(50)
def animation_fastforward():
animation_play(40)
# Main setup
animation_bootup()
# Main loop
while True:
animation_function_triggered((255, 255, 255)) # White
for _ in range(20):
animation_pause()
for _ in range(50):
animation_play()
for _ in range(150):
for _ in range(50):
animation_play()
for _ in range(50):
animation_rewind()
