SC8 over, short break
A project log for GAT Nametag SC8
A small OLED nametag addon that keeps your name always upright.
truetrue • 11/04/2024 at 21:34•0 Comments
Going to rest up a bit and take a break now that Supercon is over.
No promises but before the end of the year I should finish assembly of all the extra nametags I have.
I also want to get the infrared code working. With updated firmware, you’ll be able to sync a contact card with someone else’s nametag, so maybe you can remember each other later. Most of the hard code is done - it’s about finishing and testing it.
RGB programs didn’t get touched like I wanted so expect several more with all program variables documented by the end of the year as well.
