Designed the base stand and acrylic insert. Very rushed but it should work. Then I went to sleep.
PCBs arrived today. Just opened the box. I'll cut out a base and test fitment while testing the code. If it works then I guess I'll be laser cutting and 3D printing all day...
One con of this design is that it is _very_ small and light. This is also the design intent, but does mean that heavy / thick USB-C cables can easily move and tilt these around. Use flexible cables.
