Lakhovsky proposed this device as a form of alternative therapy, claiming it could restore the body's natural balance and promote healing through the use of electromagnetic frequencies. While his ideas and theories have been widely discredited and are not supported by mainstream science, some people continue to use his work as a basis for alternative medical treatments.
Some of benefits according to his claim are cell revitalization by increasing the oxygen supply and the nutritional value of the blood, and activation of the body's self-healing powers and increase of the general well-being.
Lakhovsky's machine worked on a different angle or principle to Rife's. It did not attack the microbes directly, but reinforced the vitality of the organism by accelerating cellular oscillation. It was intended to revitalise the oscillations of your normally healthy cells. It was therefor the reinforced organism that successfully resists the microbes and all pathogenic causes. The machine discharged high voltage that gives off electromagnetic pulses with an emphasis on producing the greatest number or widest range of frequencies/harmonics as possible, but it cannot maintain 1 steady frequency which was what Rife was doing to resonate a microbe to death.
This project is sponsored by PCBWay. This year, PCBWayorganizes the Seventh Project Design Contest where, in addition to Electronic and Mechanical Project, also has been added a new category: STM32 Project. For the best selected projects are provided rich prizes in cash, coupons and special gifts. Submit your project for participation in this Contest from 2nd, Sep, 2024 to 19th, Jan, 2025. For more details and instructions visit the given page. Let PCBwayalways be your first choice.
The Multiple Wave Oscillator machine generally consists of two parts :
- high voltage and high frequency impulses source, usually a Tesla coil.
- and other part are two specially designed antennas.
First, let me explain the first part, which is the Tesla Transformer.
Its function is to generate an extremely high alternating voltage of the order of tens and up to hundreds of thousands of volts, under the action of which a variable magnetic field is created. In his original device, Lakhovski used a Spark Gap type of Tesla Transformer, and I use a Solid State type of Tesla Transformer, because it is much more durable, simpler to make, and more compact. I want to point out a few facts, because I had reactions after making the previous device like this, with claims that it was not originally made. Namely, every Tesla Transformer in the world has its own resonant frequency, regardless of whether it is a spark gap or Solid State. In fact, it is the shape of the antenna that generates a greater number of harmonics in a wide range of frequencies. Detailed instructions for making the Tesla Transformer that I will use in this project can be found in one of my previous videos.
In fact, Lakovski's discovery is the specially designed antennas (with Golden Ratio pattern) that act as toploads with several different capacities.
This small antenna serves to receive the emitted radiation. I will perform an analysis of the signal directly from the Tesla Transformer independently, as well as a comparison with the case when I connect Lakhovsky Antennas to it. I will repeat this test at several frequencies in the range of about...
mircemk
