After the parts were finished printing, I cut a hand outline out of foam board and used plastic rivets to hold the three gears on. I used hot glue to hold the motor mount to the foam board. The motor starts to stall at voltages below 2V, and that is about the speed that I want the Vulcan Salute to run at, so now I am designing a smaller pinion gear and a larger bull gear.
