Setting up the toolchain
A project log for Sparkfun RED-V bare metal
I wanted to learn RISC-V, not on an emulator, but on a real bare metal RISC-V processor. Even though Sparkfun RED-V is no longer produced.
olaf-baeyensOlaf Baeyens 10/18/2024 at 19:030 Comments
The tool-chain is designed for Linux, so I use a Raspberry PI to program the RED-V board.
Run "sudo apt install gcc-riscv64-unknown-elf"
The tool-chain is 64 but it can generate the 32 bit RISC-V instruction-set.
The inspiration is taken from this YouTube: This is the BEST Board to Learn RISC-V Assembly.
