Creating string methods for logging
A project log for Sparkfun RED-V bare metal
I wanted to learn RISC-V, not on an emulator, but on a real bare metal RISC-V processor. Even though Sparkfun RED-V is no longer produced.
olaf-baeyensOlaf Baeyens 10/24/2024 at 17:330 Comments
For debugging we need a way to handle strings, so lets first build C like string functions.
I start with macro's, I wand the ability to create then inline when needed for speed and as a function call.
List contains a small sample of the string macro's.
Still in development I need to think how this will be used in my code.
I can give you a clue: In this case chatGPT can create code that helps a lot, but you need to manually check every generated code line. We can optimize later on, for now we need something working.
# string-macros.s
# Copy string (ASCIIZ)
.macro STRCPY dest_string_ptr, src_string_ptr
    la a0, \dest_string_ptr         # dest_string_ptr
    la a1, \src_string_ptr          # src_string_ptr
    jal _strcpy
.endm
#  String copy with specific length
.macro STRNCPY dest_string_ptr, src_string_ptr, len
    li a2, \len                     # Load the specified length into a0
    jal _strncpy
.endm
# FILL BYTES
.macro FILL_BYTES dest_ptr, value, length
    la a0, \dest_ptr            # Load destination address into t3
    li a1, \value               # Load value into t0
    li a2, \length              # Load length into t1
    jal _fill_bytes
.endm
# FILL BYTES STRING (ASCIIZ)
.macro FILL_STRING dest_ptr, value, length
    li t0, \value               # Load the value to be repeated into t0
    li t1, \length              # Load the length into t1
    la t3, \dest_ptr            # Load the destination address into t3
fill_string_loop:
    sb t0, 0(t3)                # Store the value into the destination address
    addi t3, t3, 1              # Increment the destination address
    addi t1, t1, -1             # Decrement the length
    bnez t1, fill_string_loop   # If length is not zero, repeat the loop
    sb zero, 0(t3)              # Store null character at the end
.endm
# Get string length (ASCIIZ)
.macro STRLEN dest_reg, input_string_ptr
    la t0, \input_string_ptr
    li \dest_reg, 0
.loop_strlen:
    lb t1, 0(t0)
    beqz t1, .end_strlen          # If t1 is zero (null-terminator), exit loop
    addi \dest_reg, \dest_reg, 1
    addi t0, t0, 1                # Move to the next character
    j .loop_strlen
.end_strlen:
.endm
 Accompanying code
# strings.s
.section .text
.text
.globl _fill_bytes
.globl _strcpy
.globl _strncpy
# FILL BYTES
_fill_bytes:
    addi t0, a0, 0              # Load destination address into t0
    addi t1, a1, 0              # Load value into t1
    addi t2, a2, 0              # Load length into t2
fill_bytes_loop:
    sb t1, 0(t0)                # Store byte from t0 to the destination address
    addi t0, t0, 1              # Increment destination address
    addi t2, t2, -1             # Decrement length
    bnez t2, fill_bytes_loop    # If length is not zero, repeat the loop
    ret
_strcpy:
    addi t0, a0, 0              # Load the destination string pointer to t0
    addi t1, a1, 0              # Load the source string pointer to t1
.loop_strcpy:
    lbu t2, 0(t1)
    beqz t2, .end_strcpy        # If t2 is zero (null-terminator), exit loop
    sb t2, 0(t0)                # Copy the character to the destination
    addi t0, t0, 1              # Move to the next character in src
    addi t1, t1, 1              # Move to the next character in dest
    j .loop_strcpy
.end_strcpy:
    sb zero, 0(t0)                  # Null-terminate the destination string
    ret
_strncpy:
    addi t2, a2, 0              # Load the specified length into t2
.loop_strncpy:
    beqz t2, .end_strncpy       # If t2 is zero (length reached), exit loop
    lb t3, 0(t1)
    sb t3, 0(t0)                # Copy the character to the destination
    addi t0, t0, 1              # Move to the next character in dest
    addi t1, t1, 1              # Move to the next character in src
    addi t2, t2, -1             # Decrement the length
    j .loop_strncpy
.end_strncpy:
    ret
