Improving the make files, we now want to to compile with debug, trace and logging level.
make DEBUG_LEVEL=2 TRACE_LEVEL=1 LOG_LEVEL=5
Complete makefile
# Toolchain
TOOLCHAIN_PREFIX = riscv64-unknown-elf-
CC = $(TOOLCHAIN_PREFIX)gcc
OBJCOPY = $(TOOLCHAIN_PREFIX)objcopy
# Default flag values (can be overridden from the command line)
DEBUG_LEVEL ?= 2
TRACE_LEVEL ?= 1
LOG_LEVEL ?= 5
# Flags
ASFLAGS = -march=rv32g -mabi=ilp32 -static -mcmodel=medany \
-fvisibility=hidden -nostdlib -nostartfiles -I$(INCLUDE_DIR)
LDFLAGS = -T sparkfun-red-v.ld
# Add flag definitions to ASFLAGS
ASFLAGS += -DDEBUG_LEVEL=$(DEBUG_LEVEL) -DTRACE_LEVEL=$(TRACE_LEVEL) -DLOG_LEVEL=$(LOG_LEVEL)
# Directories
SRC_DIR = src
BOOT_DIR = $(SRC_DIR)/boot
INCLUDE_DIR = $(SRC_DIR)/include
DATA_DIR = $(SRC_DIR)/data
UNIT_TESTS_DIR = $(SRC_DIR)/unit-tests
MODULES_DIR = $(SRC_DIR)/modules
BUILD_DIR = build
# Source Files
GLOBAL_CONSTANTS_FILE = $(INCLUDE_DIR)/global_constants.s
SRC = $(GLOBAL_CONSTANTS_FILE) \
$(INCLUDE_DIR)/constants.s \
$(DATA_DIR)/data.s \
$(DATA_DIR)/rodata.s \
$(DATA_DIR)/bss.s \
$(wildcard $(UNIT_TESTS_DIR)/strings-module/*.s) \
$(wildcard $(MODULES_DIR)/debug-module/*.s) \
$(wildcard $(MODULES_DIR)/strings-module/*.s) \
$(wildcard $(MODULES_DIR)/info-module/*.s) \
$(BOOT_DIR)/boot.s \
$(SRC_DIR)/main.s
# Object Files
OBJ = $(patsubst $(SRC_DIR)/%.s,$(BUILD_DIR)/%.o,$(SRC))
# Targets
ELF = $(BUILD_DIR)/main.elf
HEX = $(BUILD_DIR)/main.hex
.PHONY: all clean
# Default Target
all: $(BUILD_DIR) $(HEX)
# Create build directory
$(BUILD_DIR):
@mkdir -p $(BUILD_DIR)
# Rule to build hex file from ELF
$(HEX): $(ELF)
$(OBJCOPY) -O ihex $< $@
# Rule to build ELF from object files
$(ELF): $(OBJ)
$(CC) $(ASFLAGS) $(LDFLAGS) $^ -o $@
# Rule to compile .s files to .o files
$(BUILD_DIR)/%.o: $(SRC_DIR)/%.s
@mkdir -p $(dir $@)
$(CC) $(ASFLAGS) -c $< -o $@
# Clean up build artifacts
clean:
rm -rf $(BUILD_DIR)
