We need some kind of debugging/logging/tracing when we build our OS
So we need to define in constants.cs we now defined logging levels
# Debugging Levels =====================================================
# Define constants for debug levels
.set DEBUG_LEVEL_RELEASE, 0
.set DEBUG_LEVEL_NORMAL, 1
.set DEBUG_LEVEL_VERBOSE, 2
# Set default DEBUG_LEVEL if not defined
.ifndef DEBUG_LEVEL
.set DEBUG_LEVEL, DEBUG_LEVEL_NORMAL
.endif
# Tracing Levels =======================================================
.set TRACE_LEVEL_NO_TRACING, 0
.set TRACE_LEVEL_TRACING, 1
# Set default TRACE_LEVEL if not defined
.ifndef TRACE_LEVEL
.set TRACE_LEVEL, TRACE_LEVEL_TRACING
.endif
# Logging Levels =======================================================
.set LOG_LEVEL_NONE, 0
.set LOG_LEVEL_INFO, 1
.set LOG_LEVEL_WARN, 2
.set LOG_LEVEL_ERROR, 3
.set LOG_LEVEL_DEBUG, 4
.set LOG_LEVEL_TRACE, 5
# Set default LOG_LEVEL if not defined
.ifndef LOG_LEVEL
.set LOG_LEVEL, LOG_LEVEL_INFO
.endif
Then we define the debug macro.
(I think we need to do some push and pop of registers in the future but for now this is enough.)
# debug-macros.s
.include "./src/include/constants.s"
# DEBUG message_ptr
.if DEBUG_LEVEL > 0
.macro DEBUG message_ptr
la a0, STRINGS_DEBUG_START_MSG
jal puts
la a0, \message_ptr
jal puts
la a0, CRLF
jal puts
.endm
.else
# No operation when DEBUG is disabled
.endm
.endif
And we are creating logging macros:
# Generic LOG macro
.macro LOG message_ptr, level
# Only log if the current LOG_LEVEL is greater than or equal to the specified level
.if LOG_LEVEL >= \level
la a0, STRINGS_LOG_START_MSG
jal puts
la a0, \message_ptr
jal puts
la a0, CRLF
jal puts
.endif
.endm
# Specific log level macros for convenience
# LOG_INFO message_ptr
.macro LOG_INFO message_ptr
.if LOG_LEVEL >= LOG_LEVEL_INFO
LOG \message_ptr, LOG_LEVEL_INFO
.endif
.endm
# LOG_WARN message_ptr
.macro LOG_WARN message_ptr
.if LOG_LEVEL >= LOG_LEVEL_WARN
LOG \message_ptr, LOG_LEVEL_WARN
.endif
.endm
# LOG_ERROR message_ptr
.macro LOG_ERROR message_ptr
.if LOG_LEVEL >= LOG_LEVEL_ERROR
LOG \message_ptr, LOG_LEVEL_ERROR
.endif
.endm
Now we can use it like this:
LOG_INFO VERSION_INFO
LOG_INFO STRINGS_TEST_START_MSG
LOG_INFO SEPARATOR_DOUBLE_LINE
LOG_INFO STRINGS_TEST_STRCPY_MSG
STRCPY scratch1024, STRING_TEST_MSG
LOG_INFO scratch1024
