The tool-chain is designed for Linux, so I use a Raspberry PI to program the RED-V board.
Run "sudo apt install gcc-riscv64-unknown-elf"
The tool-chain is 64 but it can generate the 32 bit RISC-V instruction-set.
The inspiration is taken from this YouTube: This is the BEST Board to Learn RISC-V Assembly.
