For debugging we need a way to handle strings, so lets first build C like string functions.
I start with macro's, I wand the ability to create then inline when needed for speed and as a function call.
List contains a small sample of the string macro's.
Still in development I need to think how this will be used in my code.
I can give you a clue: In this case chatGPT can create code that helps a lot, but you need to manually check every generated code line. We can optimize later on, for now we need something working.
# string-macros.s
# Copy string (ASCIIZ)
.macro STRCPY dest_string_ptr, src_string_ptr
la a0, \dest_string_ptr # dest_string_ptr
la a1, \src_string_ptr # src_string_ptr
jal _strcpy
.endm
# String copy with specific length
.macro STRNCPY dest_string_ptr, src_string_ptr, len
li a2, \len # Load the specified length into a0
jal _strncpy
.endm
# FILL BYTES
.macro FILL_BYTES dest_ptr, value, length
la a0, \dest_ptr # Load destination address into t3
li a1, \value # Load value into t0
li a2, \length # Load length into t1
jal _fill_bytes
.endm
# FILL BYTES STRING (ASCIIZ)
.macro FILL_STRING dest_ptr, value, length
li t0, \value # Load the value to be repeated into t0
li t1, \length # Load the length into t1
la t3, \dest_ptr # Load the destination address into t3
fill_string_loop:
sb t0, 0(t3) # Store the value into the destination address
addi t3, t3, 1 # Increment the destination address
addi t1, t1, -1 # Decrement the length
bnez t1, fill_string_loop # If length is not zero, repeat the loop
sb zero, 0(t3) # Store null character at the end
.endm
# Get string length (ASCIIZ)
.macro STRLEN dest_reg, input_string_ptr
la t0, \input_string_ptr
li \dest_reg, 0
.loop_strlen:
lb t1, 0(t0)
beqz t1, .end_strlen # If t1 is zero (null-terminator), exit loop
addi \dest_reg, \dest_reg, 1
addi t0, t0, 1 # Move to the next character
j .loop_strlen
.end_strlen:
.endm
Accompanying code
# strings.s
.section .text
.text
.globl _fill_bytes
.globl _strcpy
.globl _strncpy
# FILL BYTES
_fill_bytes:
addi t0, a0, 0 # Load destination address into t0
addi t1, a1, 0 # Load value into t1
addi t2, a2, 0 # Load length into t2
fill_bytes_loop:
sb t1, 0(t0) # Store byte from t0 to the destination address
addi t0, t0, 1 # Increment destination address
addi t2, t2, -1 # Decrement length
bnez t2, fill_bytes_loop # If length is not zero, repeat the loop
ret
_strcpy:
addi t0, a0, 0 # Load the destination string pointer to t0
addi t1, a1, 0 # Load the source string pointer to t1
.loop_strcpy:
lbu t2, 0(t1)
beqz t2, .end_strcpy # If t2 is zero (null-terminator), exit loop
sb t2, 0(t0) # Copy the character to the destination
addi t0, t0, 1 # Move to the next character in src
addi t1, t1, 1 # Move to the next character in dest
j .loop_strcpy
.end_strcpy:
sb zero, 0(t0) # Null-terminate the destination string
ret
_strncpy:
addi t2, a2, 0 # Load the specified length into t2
.loop_strncpy:
beqz t2, .end_strncpy # If t2 is zero (length reached), exit loop
lb t3, 0(t1)
sb t3, 0(t0) # Copy the character to the destination
addi t0, t0, 1 # Move to the next character in dest
addi t1, t1, 1 # Move to the next character in src
addi t2, t2, -1 # Decrement the length
j .loop_strncpy
.end_strncpy:
ret
