I use them for storing my projects, most of them fit just fine. The newer versions don't come with the cool sticker backside where the label goes in, so I had to research the dimensions etc, only to find out that there is a label to cut out of the instruction manual - but who reads that, right? :D Anyway, here are the dimensions of the label that I found out. Would be cool to find a label generator of some sort.
