Loop Filter Shoot Off
A project log for Software Phase Locked Loop
The 567 tone decoder is perhaps most famous Phase Locked Loop (PLL) chip. This project looks at an Arduino software PLL.
agpcooperagp.cooper • 02/20/2017 at 01:47•0 Comments
Loop Filters
I have been working my way through the loop filter types, so far:
No problem with the first three:
Low Pass
PID
Lead-Lag
The Active Lead Lag Filter
Here are the analog domain basic loop filters. The problem filter is shown at the bottom of the image:
(source: http://www.globalspec.com/reference/38390/203279/2-6-second-order-phase-locked-loops)
I have plotted the S domain versus the the modelled Z domain and the Z domain is good up until about Nyquist, so no problems:
The recursive equation was:
The issue is that this filter cannot be used directly. The DC gain is +46dB and as the structure is that of an integrator and the PD is 0 to K, the filter just blows up:
This can be fixed by using a differential PD (i.e. -K/2 to +K/2) or by using a filter like the second filter below:
(source: elcrost.com/wp-content/uploads/2016/11/pll-circuit-page-2-rf-circuits-next-gr-phase-locked-loop-fm-demodulator-part3_pll_i-pdf-tutorial-zambezi.jpg)
After substituting the PD for a differential PD (i.e. -K/2 to +K/2) I get something that basically works:
(Note that the vertical scale has changed compared to the other PLL filters)
The analog equivalent is:
K 4000 =KpKv
R1 5600 R
R2 5600 R
C 0.000000100 F
T1 0.00056
T2 0.00056
WN 2673 =sqrt(K/T1)
D 0.75 =T2/2*sqrt(K/T1)
The main advantage of the last filter is greater range of control of damping factor and natural frequency.
Choosing a Loop Filter (The Shoot Off)
Now that I have all the filters working which one to use going forward? Active Lead-Lag or PID?
Active Lead-Lag Loop
Inputs:
Intermediate:
Code (after calculating Z-transform coefficients):
PID Loop (First Order)
Inputs:
Intermediate:
Output:
Code:
Conclusion (The Shoot Off Results)
It looks rather like a "no-brainer" to go with PID from a computational point of view (all other things appearing to be equal). Funny how the common wisdom of PID in the discrete domain is confirmed!
AlanX
