If you are currently using this library I recommend you upgrade to v1.0.3 which fixes an issue with invalid current and power readings if low values of max expected amps are specified (Issue #4).
To see what version you currently have execute:
pip show pi-ina219To upgrade simply execute:
sudo pip install git+git://github.com/chrisb2/pi_ina219.git
Chris
