I am working on porting this library to MicroPython on the pyboard. Currently the functionality is working correctly based on manual testing and I am looking to port the unit tests.
Take a look at the project here.
A project log for Raspberry Pi INA219 voltage/current sensor library
Python library for Raspberry Pi which provides an easy to use interface for the INA219 voltage and current sensor from Texas Instruments.
