Some tests in low voltage confirm that the hardware is ok !
Here is the setup with 1 switch and a 12V car light bulb.
For now, the firmware just blink the relay. The next big step is to implement the OneWire slave and the current measurement.
A project log for Low cost Smart Switch
Control and monitor any lighting setup : a low cost 1-Wire module.
