Redesign of the Adafruit 5752 4x rotary encoder board into a SAO.
Instead of running adafruit seesaw firmware on attiny817 or samd09 I put in a WaveShare RP2040-ZERO. Also I couldn't find transparent shaft rotary encoders so I replaced them with ones with RGB LED inside.
The Adafruit board has neopixels under each encoder and would shine the light up the stem but I couldn't find where I could order rotary encoders with click and clear stem. Instead I'm using ones with RGB LEDs in the encoder will strobe through the 4 encoders to control the RGB LEDs and read the push-button inputs with a limited number of pins.
In searching for parts I found some related designs
