Find it here below.
// Tiberium Sketch
// This sketch will fade a LED in and out ("breathing")
// SW PWM for Atmega16
// 2017-02-19 Stefan-Xp
int LED_Pin = A6; // Pin Number of the desired LED Output
int Periode = 10000; // in µs, so the PWM will have ~100Hz
int OnTime = Periode; // Ontime, determines how bright a LED will appear
int Step = 40; // Stepsize, determines how fast the Transistion will be
void setup() {
// Initialise LED Pin
pinMode(LED_Pin, OUTPUT);
void loop() {
// Set to On
digitalWrite(LED_Pin, LOW);
// Wait the Time which the LED should stay on
delayMicroseconds(OnTime);
// Set to Off
digitalWrite(LED_Pin, HIGH);
// Wait the remeining Time of the Cycle
delayMicroseconds(Periode - OnTime);
// Determine if the Stepdirection should be changed
// (>= Period Time (100%) or below 30%)
if(OnTime + Step >= Periode || OnTime <= Periode*0.30)
Step = -Step;
// Increase / Decrease OnTime
OnTime += Step;
It is pretty simple. Sorry if you are Disappointed :-/Have a nice Sunday!
