Laser Stabilization using Red Pitaya
To goal of this poject is to transfer the stability of a laser who's frequency is locked to a atomic transition, to an unstable laser.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
While lasers are inherently very stable, for many high precision scientific experiments, an even higher degree of precision is necessary. To goal of this poject is to transfer the stability of a laser who's frequency is locked to a atomic transition, to an unstable laser.
The basic setup will use well a established technique of a scanning transfer cavity lock.
Todo
Get get analog inputs setup
Output trianglewave
Sync triangle wave with scan
Data analyser to detect voltage peaks
Identify wavelength difference
Provide laser feedback
Setup GUI
