#4 Project log
A project log for Create a program to speed up 3D printing
Create a program to speed up 3D printing for FDM 3D printer
tranvinhquangTRAN.VINH.QUANG 11/07/2024 at 11:120 Comments
After making some changes, I have created a python program that can automatically adjust the speed based on the distance. The program will create a new gcode file based on the old gcode file, can customize the distance to change at the variable distv1 (mm) and the speed to decrease at the variable speedv1. The next step is to create an executable file so that it can be used more friendly without having to open visual studio anymore.
And here is the code of the program:
* The MIT License (MIT)
* Copyright (c) 2024 by TRAN VINH QUANG
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
import numpy as np
with open('test-gcode.gcode','r') as file, open("new-gcode.gcode", "w+") as newgcode:
firstpoint = [0,0,0,0,0,"G0"]
secondpoint = [0,0,0,0,0,"G0"]
line = file.readlines()
ptr1 = 1
ptr2 = 1
ptr3 = 1
ptr4 = 1
ptr5 = 1
ptr6 = 1
ptr7 = 1
speedv1 = 2.0
distv1 = 3.0
for i in range(len(line)):
words2 = line[i].split()
firstpoint[0] = secondpoint[0]
firstpoint[1] = secondpoint[1]
firstpoint[2] = secondpoint[2]
firstpoint[3] = secondpoint[3]
firstpoint[4] = secondpoint[4]
if words2:
ptr1 += 1
if words2[0] == 'G1' or words2[0] == 'G0':
ptr2 += 1
for j in range(len(words2)):
if words2[j][0] == 'X':
secondpoint[0] = float(words2[j].replace('X',''))
if words2[j][0] == 'Y':
secondpoint[1] = float(words2[j].replace('Y',''))
if words2[j][0] == 'Z':
secondpoint[2] = float(words2[j].replace('Z',''))
if words2[j][0] == 'F':
secondpoint[3] = float(words2[j].replace('F',''))
if words2[j][0] == 'E':
secondpoint[4] = float(words2[j].replace('E',''))
secondpoint[5] = words2[0]
p1 = np.array([firstpoint[0],firstpoint[1],firstpoint[2]])
p2 = np.array([secondpoint[0],secondpoint[1],secondpoint[2]])
squared_dist = np.sum((p1-p2)**2, axis=0)
dist = np.sqrt(squared_dist)
if dist <= distv1:
res = [sub.replace(words2[j], "dF"+str(float(words2[j].replace("F",""))/speedv1)) for sub in words2]
line[i] = ' '.join(res)+"\n"
ptr3 += 1
else:
ptr4 += 1
else:
ptr5 += 1
if dist <= distv1:
res = [sub.replace(words2[0], words2[0]+" F"+str(float(words2[0].replace("F",""))/speedv1)) for sub in words2]
else:
if words2[1][0] == 'F':
res = [sub.replace(words2[1], "F"+str(secondpoint[3]/speedv1) ) for sub in words2]
else:
res = [sub.replace(words2[1], "F"+str(secondpoint[3]/speedv1) +" "+ words2[1]) for sub in words2]
else:
res = [sub.replace(words2[0], words2[0]+" F600") for sub in words2]
else:
res = [sub.replace(words2[1], "F600" ) for sub in words2]
else:
res = [sub.replace(words2[1], "F600 "+ words2[1]) for sub in words2]
else:
ptr6 += 1
else:
ptr7 += 1
newgcode.writelines(line)
