There's still a fair amount of unexplored data and code. Can't say much for data, but code you can figure out where functions demarcate in many cases just by looking for the C9 that is the RET that often punctuates a function end. I found several 'orphan' functions this way.
As a new tack, I searched the binary for the orphaned function's address. Ostensibly to find a call site, but many times I found it in a list of addresses that mapped to other orphaned functions. So I had found some dispatch tables. Oftentimes is was easy to work backwards from such to find the start of the function table because it would abut some code ending. Then I could do a similar address search to find the code that dispatches through the table.
It was a bit tedious, but there are presently 42 such dispatch tables currently found! And just for fun, it turns out that there are dispatch tables of dispatch tables in some cases! There is a huge table of 128 entries at 4002h, a double-dispatch table at 2DA6 (with associated paramters table at 2DE0) and another double-dispatch table at 2200.
With that many dispatch tables, this surely is some state machine design. To think I was daunted by the one in ROM 4! This is proportionately larger. But who knows, this might be a gift as it might make the intent clearer.
Bloopers
Some amusing treats were nullsubs that have a subsequent jump to the nullsub. (The code in the subsequent jump is not referenced anywhere.)
3E9C nullsub_4: 3E9C C9 ret 3E9D C3 9C 3E jp nullsub_4
or
3EA8 nullsub_5: 3EA8 C9 ret 3EA9 C3 A8 3E jp nullsub_5
And a dispatch table of jump addresses that ends with a ret; lol.
... 40FC 9E 41 dw sub_419E ; XXX IX -= 4 40FE 9E 41 dw sub_419E ; XXX IX -= 4 4100 9E 41 dw sub_419E ; XXX IX -= 4 4102 C9 ret
My personal favorite:
0475 18 00 jr loc_477 ; well let's jump right on that!
0477 loc_477:
...I think more symptoms of machine generated code.
It took a day, but it got me to my desired 100% code coverage milestone. Now that I have the puzzle pieces, it's time to see what picture emerges.
ziggurat29
