I did some measurements to verify the dynamic properties of the power supply.
First, i measured the transient step load response in CV mode. Output voltage was set to 10V, load resistance was 5 Ohms switched by MOSFETs.
(Yellow trace is the output voltage. Blue trace is the gate control signal)
Transition from CV to CC (and vice versa). Output voltage was to 10V, current limit to 1A and the load resistance was 5 Ohms.
Voltage rise after power-up
