The supports of the system are of 2 types, the conventional one, which is the first picture below and another supporter that combines with a base holder (second picture). The STL file name for this second support that it is inserted in the base holder as it can be viewed in the pics is BottomSupporterToBaseHolder.stl
The best option in my humble opinion is to use a base holder to hold all the device as the second picture shows.
As the image below shows, we have developed a blade (left) that is wider and have an special structure that gives more impulse than a traditional blade as the one on the right of the pic.
Configure the Wind Turbine for the Different Wind Forecasts
The device can be configured for placing a gearbox with range of 10x1 or reduce the hardness of the gearbox if there is not a low of wind available or it is needed to generate more RPM, by changing the gears to a range of 3x1. It can be done also by placing one or two dc motors.
Innovation Developing New Counter Rotation Devices
Here you have some pictures and videos showing the developments of this new innovative devices for our next Kickstarter campaign. If you like it, just follow the project to encourage us in this adventure!!!
esposcar90
