11.26 inch 440x1920 display to make glow clock
Use a Raspberry Pi 2 and an ElecLab 11.26 inchs 440x1920 display to create a glow clock and set an alarm.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A 10" LED clock was broken, so I made a clock with PI4 and ElecLab 11.26 Inch 440x1920 HDMI Screen. I used pygame to set up two alarms, one for the table to remind the kids that it's time to go to school, and the other for easy viewing of the clock. I gave it three skins and an old-fashioned clock ticking sound, and of course a warning box and a warning sound to clearly remind them.
The shell that can be installed on the Raspberry Pi is still being printed, and it will be assembled into a complete set and all the information will be sorted out for sharing.
The shell has been printed and assembled. The Raspberry Pi 3 is running Bookworm 64. The speed is a bit slow, but it is just enough to run this simple application. For testing, I set the hourly time and the school reminder.
The next step is to display the weather.
Display Links and case links:
https://www.amazon.com/ElecLab-440x1920 ... B0CTMYWPSP
https://github.com/eleclab-rpi/7.84_8.8_11.26INCH_HDMI
