——————Step 1: Design Acrylic Cutting Pattern——————
Before diving into creating Halloween silhouette lamps, the first step is to decide on the desired silhouette patterns. It can be pumpkins, ghosts, bats, or anything else related to Halloween. The key is to ensure that the patterns have clear outlines so that they can create a crisp silhouette effect when cut and illuminated.
(Attached below is the AI project file I made)
——————Step 2: Prepare Ambient Light Strips——————
Of course, ambient lighting is essential. I used LED copper wire lamps from Elecrow's website. They offer a total of 5 colors to choose from, and I selected the yellow LED lamp.
————Step 3: Assembling Acrylic Silhouette Lights————
Once we have received the cut acrylic and LED ambient lights, we can proceed with the assembly.
(1) First, peel off the protective film from the acrylic.
(2) Then, individually thread a thin string through the holes located directly above each acrylic board. Use scissors to cut the string to the appropriate length, providing a secure attachment.
(3) Next, wrap the copper wire of the LED lights around the reserved holes on each acrylic board, connecting all the acrylic boards together.
Finally, turn on the LED lights, and your Halloween decoration is complete!
Joshua A.S.
davedarko
Jan
Steve Pomeroy
