Documentation update
SPI1 is working with the following hardware setup:
#define | GP | Wire | SD Adapter | SD card pin |
SD_CS | 13 | green | D3 | 2 |
SD_DI | 12 | black | D0 | 7 |
SD_DO | 11 | blue | CMD | 3 |
SD_CLK | 10 | grey | CK | 5 |
This was more difficult than it should be, but finally it is done.
SDcard test. Writing to test.txt...done. test.txt: 1161011151161051101033249443250443251461310 SD Card Speed Test... Writing to byte.txt...done. Duration [millisec]: 8250 FileSize [bytes]: 1048576 Write Speed(8bit) [KByte/sec]: 128 Writing to 16bit.txt...done. Duration [millisec]: 13657 FileSize [bytes]: 2097152 Write Speed(16bit) [KByte/sec]: 157 Writing to 32bit.txt...done. Duration [millisec]: 23569 FileSize [bytes]: 4194304 Write Speed(32bit) [KByte/sec]: 178 done. >d SDcard root directory. System Volume Information/ IndexerVolumeGuid 76 CREATION: 2024-12-20 22:24:20 LAST WRITE: 2024-12-20 22:24:22 WPSettings.dat 12 CREATION: 2024-12-20 22:24:40 LAST WRITE: 2024-12-20 22:24:42 test.txt 18 CREATION: 2098-01-01 00:00:12 LAST WRITE: 2098-01-01 00:00:42 byte.txt 1048576 CREATION: 2098-01-01 00:00:42 LAST WRITE: 2098-01-01 00:00:58 16bit.txt 2097152 CREATION: 2098-01-01 00:00:58 LAST WRITE: 2098-01-01 00:01:22 32bit.txt 4194304 CREATION: 2098-01-01 00:01:22 LAST WRITE: 2098-01-01 00:01:12 >uSD Card removed!
And here is the instruction to fix the traces before putting on the uSD holder to hide the mod:
