The HPDL-1414 is a 16-segment LED display with four printable fields that is over twenty years old. It has a red GaAsP screen to which we can add the epithet "smart", because it is capable of printing alphanumeric characters on its fields.
The screen is controlled by a CMOS integrated circuit embedded in a plastic housing.This circuit contains RAM, ASCI II decoder, multiplexer and LED drivers. Thanks to these features, no additional components are needed to connect this display to the microcontroller. More displays can be connected in series, where for each subsequent one it is necessary to assign another GPIO to the WR pin, similar to the SPI interface.
In one of my previous videos I presented you a miniature clock with these displays, as well as the way in which static and moving text can be written on it. Unfortunately at that moment I didn't manage to create a version of the code in which I could adjust the time manually with buttons, which would make this nice retro clock complete, although when making the case I incorporated three buttons for this purpose.
This time I will present you the new version of this project, where in addition to manually setting the time, I also added a Alarm function with a pulsating beep on a small Buzzer.
The device is very simple to make and consists of several components:
- Arduino nano microcontroller
- 2 pcs. HPDL-1414 Led displays
- DS3231 Realtime clock module
- Three Buttons,
- And small active Buzzer
This project is sponsored by PCBWay. This year, PCBWayorganizes the Seventh Project Design Contest where, in addition to Electronic and Mechanical Project, also has been added a new category: STM32 Project. For the best selected projects are provided rich prizes in cash, coupons and special gifts. Submit your project for participation in this Contest from 2nd, Sep, 2024 to 19th, Jan, 2025. For more details and instructions visit the given page). Let PCBwayalways be your first choice.
Now follows a brief description of the device's functions. Immediately after switching on, a moving demo text appears on the display, after which the set time is displayed in the form of Hours, Minutes, and Seconds. To enter the menu for setting the correct time, press the "S" button.
Now with the "H" button the hour is set, and with the "M" button the minutes are set. With the next click on the "S" button, we enter the menu for setting the alarm.
The setting principle is the same as before, only this time the letter "A" appears at the beginning, unlike the previous menu.
The alarm is activated at the set time in the form of short beeps with a duration of 500mS, and is deactivated simply by pressing the set button.
And finally a short conclusion. This is a small, simple, but really interesting unusual clock that shows the time on retro displays made by Hewlett-Packard at the turn of the last century, and was also used for calculators and measuring instruments.
#include <HPDL1414.h>
#include <RTClib.h>
#include <Wire.h>
const byte dataPins[7] = {2, 3, 4, 5, 6, 7, 8}; // Segment data pins: D0 - D6
const byte addrPins[2] = {A1, A2}; // Segment address pins: A0, A1
const byte wrenPins[] = {A0, A3}; // Write Enable pins (left to right)
RTC_DS3231 rtc;
char msg[] = " *** MICRO CLOCK - MIRCEMK *** ";
char t[32];
HPDL1414 hpdl(dataPins, addrPins, wrenPins, sizeof(wrenPins));
// Button pins
const int buttonHourPin = 9;
const int buttonMinutePin = 10;
const int buttonSetPin = 11;
// Buzzer pin
const int buzzerPin = 12; // Add a pin for the buzzer
// Variables for setting time and alarm manually
int hours = 0;
int minutes = 0;
int alarmHours = 0;
int alarmMinutes = 0;
bool setMode = false; // Time setting mode flag
bool alarmMode = false; // Alarm setting mode flag
bool alarmEnabled = false; // Alarm enabled flag
bool alarmActive = false; // Alarm active (sounding) flag
bool alarmAcknowledged = false; // Alarm acknowledged (stopped) flag
// Buzzer timing
unsigned long previousMillis = 0;
const long beepInterval = 500; // 500ms on, 500ms off
bool buzzerState = false; // To track buzzer state (on/off)
void setup() {
Serial.begin(9600);
Wire.begin();
hpdl.begin();
hpdl.clear();
// Set up buttons and buzzer
pinMode(buttonHourPin, INPUT_PULLUP);
pinMode(buttonMinutePin, INPUT_PULLUP);
pinMode(buttonSetPin, INPUT_PULLUP);
pinMode(buzzerPin, OUTPUT);
digitalWrite(buzzerPin, LOW); // Make sure the buzzer is off initially
// Display scrolling message at startup
for (byte i = 0; i < (sizeof(msg) / sizeof(char)); i++) {
for (byte j = 0; j < 16; j++) {
hpdl.setCursor(j);
if (i + j < (sizeof(msg) / sizeof(char))) {
hpdl.print(msg[i + j]);
} else {
hpdl.print(" ");
delay(200);
rtc.begin();
// Initialize time variables from the RTC
DateTime now = rtc.now();
hours = now.hour();
minutes = now.minute();
void loop() {
// Get the current time from the RTC
// Check if the alarm is active (buzzer sounding)
if (alarmActive) {
unsigned long currentMillis = millis();
// Toggle the buzzer every 500ms (buzzerState controls on/off)
if (currentMillis - previousMillis >= beepInterval) {
previousMillis = currentMillis; // Save the last time the buzzer toggled
buzzerState = !buzzerState; // Toggle the buzzer state
digitalWrite(buzzerPin, buzzerState ? HIGH : LOW); // Turn the buzzer on or off
// Check if D11 is pressed to stop the alarm
if (digitalRead(buttonSetPin) == LOW) {
alarmActive = false; // Stop the alarm
alarmAcknowledged = true; // Mark the alarm as acknowledged
digitalWrite(buzzerPin, LOW); // Turn off the buzzer
delay(500); // Debounce delay
return; // Return to normal loop operation
// Check if we are in time or alarm setting mode
if (setMode) {
// Display the manually set time
sprintf(t, "%02d-%02d", hours, minutes);
hpdl.clear();
hpdl.print(t);
// Check if buttons to adjust hours or minutes are pressed
if (digitalRead(buttonHourPin) == LOW) {
hours = (hours + 1) % 24; // Increment hours and roll over after 23
delay(200); // Debouncing
if (digitalRead(buttonMinutePin) == LOW) {
minutes = (minutes + 1) % 60; // Increment minutes and roll over after 59
} else if (alarmMode) {
// Display the manually set alarm time
sprintf(t, "A%02d-%02d", alarmHours, alarmMinutes);
hpdl.clear();
hpdl.print(t);
// Check if buttons to adjust alarm hours or minutes are pressed
alarmHours = (alarmHours + 1) % 24; // Increment alarm hours and roll over after 23
alarmMinutes = (alarmMinutes + 1) % 60; // Increment alarm minutes and roll over after 59
} else {
// Normal operation: Display the current time from the RTC
sprintf(t, "%02d-%02d-%02d", now.hour(), now.minute(), now.second());
hpdl.clear();
hpdl.print(t);
// Check if the current time matches the alarm time and alarm is not acknowledged
if (alarmEnabled && !alarmAcknowledged && now.hour() == alarmHours && now.minute() == alarmMinutes && now.second() == 0) {
alarmActive = true; // Mark the alarm as active
previousMillis = millis(); // Initialize the timer for buzzer beeping
// Reset the alarm acknowledgement flag if the minute has changed
if (now.minute() != alarmMinutes) {
alarmAcknowledged = false; // Allow the alarm to trigger again when the time matches next
// Check if the Set button (buttonSetPin) is pressed to toggle between modes
if (digitalRead(buttonSetPin) == LOW && !alarmActive) {
if (setMode) {
// Exiting time set mode, update the RTC with the manually set time
rtc.adjust(DateTime(2024, 1, 1, hours, minutes, 0)); // Arbitrary date
setMode = false;
alarmMode = true; // Move to alarm setting mode
// Exiting alarm set mode, enable the alarm
alarmEnabled = true;
alarmMode = false; // Back to normal mode
} else {
// Enter time setting mode
setMode = true;
delay(500); // Debouncing delay
mircemk
