Sea Trial of the System
A project log for Design of an Echosounder system
Development of an Echosounder System.
luicers-labLuicer's Lab 07/03/2025 at 16:020 Comments
Web
Introduction
Once the complete system was developed, it was time to test it at sea. The goal was to take the transducer and control board on a kayak and check its performance at different depths. For this, it was necessary to design a waterproof enclosure to protect the electronics and develop a mobile app that could communicate with the control board and display the data in real time.
For this first test, a transducer with a 20 mm diameter and 4 mm thick piezoelectric crystal operating at 500 kHz was used. Although it is a small sensor working at a relatively high frequency, it was expected to reach depths of up to 15 meters.
In the future, a larger transducer is planned to improve the system’s range and sensitivity.
Waterproof Enclosure for the System
The waterproof enclosure designed is shown below:
Sistema2
The enclosure is completely waterproof and features an IP68 switch to activate the system. It also has a holder to secure the mobile phone.
Inside, the electronics are arranged as follows:
Sistema1
The control board is powered at 5 VDC by a DC/DC converter that steps down the voltage from two 18650 batteries connected in series.
Kivy App
An Android app was developed using the Kivy framework. The application communicates with the board’s HC-06 module via Bluetooth, using the Pyjnius library and the serial port profile.
The app has two main screens. On the first, the Bluetooth connection is established and measurement parameters are entered, such as:
App2
The second screen displays the measurement of ultrasound intensity as a function of depth, similar to a conventional fish finder.
App1
Sea Trial
For the sea tests, the entire system was transported on a kayak and its operation was checked at different depths.
Prueba3
The transducer was manually submerged in the water:
Prueba2
The measurement results were as follows:
Prueba1
As you can see, the system is able to display the seabed at depths between 0 and 15 meters, since the bottom line appears in the correct position. However, it was observed that the depth detection algorithm does not work optimally in this range, as it is tuned for shorter distances.
Video
Here you can watch a complete video showing the system in operation:
Conclusions and Next Steps
The sea trial was successful, demonstrating that the system can measure depth up to about 15 meters using a small, low-cost transducer.
Looking ahead, the next steps will be:
We will continue to share updates and improvements
