I Built a Mini Monitor for Server and Raspberry Pi
While working on headless servers or Raspberry Pi I kept hitting the problem that I needed a monitor but did not want to bust out a big one.
While working on headless servers or raspberry pi I kept hitting the problem that I needed a monitor but didn't want to bust out a full-size one and deal with all the space it would take up. Now I just need to grab this lil guy from my drawer and plug it in. It has an HDMI input for video and a USB-C for audio. I kinda want to make a second version that has a VGA input as well, so I don't need to use an adapter with some of my older servers.
3D Model.STEP
step - 1.42 MB - 11/04/2024 at 12:31
Download
3D Model.STL
Standard Tesselated Geometry - 955.84 kB - 11/04/2024 at 12:31
Download
3D Model.SLDPRT
sldprt - 980.62 kB - 11/04/2024 at 12:31
Download
  • 1 × Display 5-Inch 40-Pin TTL display
  • 1 × Display Driver Board 40-Pin TTL display driver board
  • 1 × USB Audio Adapter USB to 3.5mm jack audio adapter
  • 1 × USB-C Breakout USB-C 4 Pin breakout board
  • 1 × Speaker Amp PAM8403 mini speaker amplifier
View all 9 components
Michael Graham wrote 11/12/2024 at 18:17 point
Clean build. I like that the monitor cable goes through the hinge. Most of the screens from amazon have the ports lined up on the side which sticks out awkwardly
Tjiani Lucht wrote 12/04/2024 at 20:24 point
Thanks! Pros of building it ourselves right.
Shynka wrote 11/08/2024 at 21:48 point
really cool.
I usually use a hdmi to usb converter and use my laptop
