Between sessions we've been working on the motor assembly and we finally succeded the rotation. With a test code that would work on full step mode we achieved our first objective.
here is the first code that worked:
// Include the AccelStepper library:
#include "AccelStepper.h"
// Define stepper motor connections and motor interface type.
// Motor interface type must be set to 1 when using a driver
#define dirPin 2
#define stepPin 3
#define enablePin 4
#define motorInterfaceType 1
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
void setup() {
// Set the Enable pin as an output:
pinMode(enablePin, OUTPUT);
// Enable the motor driver (active LOW):
digitalWrite(enablePin, LOW);
// Set the maximum speed in steps per second:
stepper.setMaxSpeed(1000); // Adjust as needed for your motor
void loop() {
// Set the speed in steps per second:
stepper.setSpeed(1000); // Adjust for desired speed (max: setMaxSpeed value)
// Run the motor at a constant speed:
stepper.runSpeed();
The objective was then to find if if was possible to stop the rotation using a button. In this case we used the button on the Arduino: it worked but only for a couple of seconds right before rotating again. Here is the code with button :
#define dirPin 2
#define stepPin 3
#define enablePin 4
#define buttonPin 5
// Variable to track motor state
bool motorRunning = true;
// Variables for button state and debounce
bool lastButtonState = HIGH; // Previous state of the button
bool currentButtonState = HIGH;
unsigned long lastDebounceTime = 0;
const unsigned long debounceDelay = 50; // Debounce time in milliseconds
void setup() {
// Set pin modes
pinMode(buttonPin, INPUT_PULLUP); // Button with internal pull-up
// Set motor speed limits
stepper.setMaxSpeed(1000); // Maximum speed (steps per second)
stepper.setSpeed(800); // Constant speed
void loop() {
// Read the button state
bool reading = digitalRead(buttonPin);
// Check if the button state has changed (debouncing)
if (reading != lastButtonState) {
lastDebounceTime = millis(); // Reset debounce timer
if ((millis() - lastDebounceTime) > debounceDelay) {
// If the button state has stabilized and it's LOW (pressed)
if (reading == LOW && lastButtonState == HIGH) {
motorRunning = !motorRunning; // Toggle motor running state
digitalWrite(enablePin, motorRunning ? LOW : HIGH); // Enable/disable motor
lastButtonState = reading; // Update last button state
// Run the motor only if motorRunning is true
if (motorRunning) {
stepper.runSpeed();
