Ready
- Interrupt driven data reception of three digital calipers (24bit mode)
- Power on / off / reset
- Absulte / incremental measurements (mm)
- Zero values
- Enable / disable axis (attach / detach interrupts)
- Double values (radius / diameter)
- Display DRO page
- Display axis settings pages
- Serial command line interface
To do
- Spindle RPM
- Save / load EEPROM settings
- QT creator Application
