a fun detection rope
A project log for None-Position Rope Type Water Leak Sensor
It is sensitive to leaks anywhere on the cable, instantly detecting and reporting water drops via LoRaWAN®.
makerfabsMakerfabs 11/09/2024 at 09:320 Comments
Due to its unique material properties, the rope-style sensor exhibits a very high resistance value in its normal dry state, typically reaching several megohms. However, should water leakage occur, the sensor's resistance value drops rapidly when it comes into contact with water or any other conductive liquid.
