Today, I assembled the SWD connector and the FTDI breakout board from Ada Fruit. I am planning on using them in combination with OpenOCD for programming the chips. While I was at it, I also soldered one of the Si7021 breakout boards. Since I am still waiting for the last component shipment, I might play around with the sensor on the breadboard.
