New PCB Design
A project log for SpiderWing
Spider robot powered by Adafruit Feather boards and CircuitPython.
dehipudeʃhipu • 11/03/2019 at 18:23•1 Comment
As mentioned, it's time to modernize this design a little bit. So first of all, I added the PCB legs from #D1 Mini Tote, and also added footprints for contact switches at the ends of those legs. Then I switched all parts (except for headers) to SMD, because that's usually cheaper and easier to fabricate. Finally, we have some additional headers for connecting those foot switches to the Feather's pins.
The shield remains relatively simple — just a PCA9685 for servo control, and a battery holder with a power switch, and a couple of extra capacitors. The whole thing fits in 10x10cm, so you should be able to order it easily, though some fabs might complain about "multiple projects" in the design.
titimoby wrote 11/05/2019 at 13:45 • point
Full PCB version, sounds nice.
Is it you V6 ?
