After weeks of waiting, Catchcam boards have finally arrived!
I've ordered 10 boards with components assembly included. The quality of the boards is exceptional.
The boards are quite clean and the components are well soldered.
I've powered up the board, and tested the power supply voltages. They all seem fine.
Next, I will try to flash and debug a simple program. Stay tuned!
(You can pre-order the Catchcam - Speed camera Detector sample at vnucec.ivan@gmail.com.)
Ivan Vnucec
