Version 2 is now available
A project log for Mini-PI Media Server
Mini-PI Media Server for use on home network or as a wifi access point to stream media from
diddydiddy 07/20/2025 at 14:230 Comments
Version 2 has been updated with a rewritten ncurses script for reconfiguring wifi.
this script now scans the wifi network and allows a user to select the wifi they would like to connect to.
also tried to make it so that the current wifi connection is kept up (if running the reconfigure script over wifi) so that the script and ssh connection does not drop.
also updated the usb sync script so that when it runs it doesnt spam the log file but what it does pass to the log view is now more obvious to the user to tell when too unplig the usb pen.
Also made the usb script auto repair a fat file system if it detects the pen drive has errors before syncing media.
the log view can be viewed form the log view of cockpit.
