version 2.1 is now available
A project log for Mini-PI Media Server
Mini-PI Media Server for use on home network or as a wifi access point to stream media from
diddydiddy 07/21/2025 at 20:170 Comments
Version 2.1 now includes more animated backgrounds and a rewritten reconfigure-wifi.sh script.
as per always, the background you set on your device will be remembered for when you next go to the web page of the media server.
The script will ask the user to set up a main wifi connection and report connected with a link quality and bit rate along with asking the user to set up an alternate wifi connection.
if the raspberry pi looses connection it will try to autoconnect and if that fails, move to the alternate wifi connection.
so now you can set the alternate wifi for a hotspot or a friends wifi connection.
video of more backgrounds :-
More animated backgrounds
