Ubuntu based setup script uploaded
A project log for Mini-PI Media Server
Mini-PI Media Server for use on home network or as a wifi access point to stream media from
diddydiddy 07/21/2025 at 21:240 Comments
UNTESTED - so try at your own risk
Want to run this media server on an Ubuntu based distro ?
This script will install on a Ubuntu based Linux to turn any pc into a media server.
Should work as the setup script (ubuntu-based-setup.sh) will installl for the current logged in user (make sure you have local admin rights).
also checks Cockpit and attempts to download the right version for your ubuntu release.
To install, download the latest version and unzip it.
also download this ubuntu-based-setup.sh script and drop it into pi-setup folder
then make it executable and run it.
no longer need a raspberry pi, but any old pc running ubuntu should be able to run a media server.
