Just a small update to version 4.72
Fixed a small logic bomb in the version.txt that wasn't being written correctly to the apache web directory on install / upgrade. Result was that every user was notified of an update which they were already on.
this has also given me the chance to set the 'Easy Connect' button size and spacing correctly on the main page
You can download / upgrade by running the following on the Raspberry Pi (either SSH into the Pi or on the actual Pi) :-
wget -qO- https://raw.githubusercontent.com/diddy-boy/mini-pi-media-server/main/install.sh | bash
diddy
