version 1.81 is out
A project log for Mini-PI Media Server
Mini-PI Media Server for use on home network or as a wifi access point to stream media from
diddydiddy 07/15/2025 at 19:430 Comments
Version 1.81 now has an updated setup script (mini-pi-setup.sh) that now asks a user at the end of the setup if they would like to reconfigure wifi settings.
selecting no will reboot the mini-pi server.
selecting yes will then open the reconfigure wifi script (reconfigure-wifi.sh) and take the user through setting up a 5ghz or 2.4ghz connection, country type and if they want a fallback network incase the main wifi connection does not work.
The user will also be asked for a hotspot connection ssid and password.
within the zip file contains not just configs and files but also the following scripts :-
mini-pi-setup.sh  (setup this mini server). can be reran to set everything back to default.
reconfigure-wifi.sh (reconfigure wifi cards and bring them back up on next reboot)
usb-sync.sh (mount a usb pen drive and sync the Music and Video folders then unmount the pen drive afterwards)
Enjoy.
