Pi zero 2 w running powerbank use
A project log for Mini-PI Media Server
Mini-PI Media Server for use on home network or as a wifi access point to stream media from
diddydiddy 02/10/2026 at 10:480 Comments
Since the Pi zero 2 w can be powered off a power bank.
A 20,000 mah power bank easily gives over 24 Hours of use !
Only drawing 1 watt of power with everything booted up and idle and that's with the usb to etherent adapter connected as well.
You can download / upgrade by running the following on the Raspberry Pi (either SSH into the Pi or on the actual Pi) :-
wget -qO- https://raw.githubusercontent.com/diddy-boy/mini-pi-media-server/main/install.sh | bash
