Mini-Pi Media Server: Quick FAQ
- Q: Which Raspberry Pi models are supported?
- A: It is highly optimized for the Pi Zero 2 W (£14), but fully supports Pi 3, 4, and 5.
- Q: Can I use an external hard drive?
- A: Yes but only to synchronise from! The project includes an Auto-USB sync feature. Plug in a drive with "Video", "Music", or "Pictures" folders, and it will automatically sync media into the pi's media library.
- Q: Does it support 4K?
- A: The Zero 2 W handles 1080p HD effortlessly (up to 4 streams). For 4K, we recommend using a Pi 4 or 5 with an Ethernet connection. Streaming over wifi at this bandwidth is just asking for pain.
- Q: Do I need to be a Linux expert to install it?
- A: No. It’s a one-command install. Just run the script from our GitHub and it handles the entire stack setup for you.
- Q: How do I manage the server?
- A: It comes with Cockpit Web Admin pre-installed. You can manage files, check system health, and terminal into the Pi directly from your web browser—no SSH knowledge required.
diddy
