We saw that the servo motor would be too small to sustain the weight of our feet and so we tried mechanical resistances for the pedal instead. We tried 2 prototypes one with foam and one with springs we made out of metal wires. The springs had a more realistic feeling and so we have chosen this one.
We also made a 3rd prototype of our poullie system with harder cardboard to make sure it presses the button on top of the bow when we pull it. We also found our wheel for the final poullie we just need to find a way to make it higher, tubes from tin foil seem to work well.
We also continued on our code for LEDs but we do not know how we will display them
Maleluce
