december 3
A project log for KartCar
Using an existing game and creating our own alternative controllers
maleluceMaleluce 12/03/2024 at 17:040 Comments
This session we did a lot of things. Everyone had their tasks. We mostly perfected the final prototypes and took care of formating.
Celine and Maewenn : They started by designing then drawing mario object on the base of the poullie system and then painting them. They also cut out and painted a big star. Which they then fixated on the sides of the poullie. And then they worked on the dashboard. They found a wooden plank for the base and two stand on which we will be able to put the dashboard. They took the measurements. They also worked on the kart system because we realised that it was good for us to fit in it but when we tried with other people from the class who were taller, it was a tight fit. With Lucine they started talking about other solutions so that the kart can be modifiable depending on who wants to play the game.
Leila: Leila started by making a new prototype of the steering wheel because we saw that it was not very clean and when we tested the game it did not do what we wanted it to do very smoothly. Once this was done she worked on soldering 8 other LEDs with resitances. Finally we tested the new steering wheel and saw that our problem was not completely fixed so she and Lucine worked on that.
Lucine: Lucine started by painting the foam ball to make it look like a mario mushroom (this button is used for the button made for sliding. Then she drew and painted the flowers which decorate the poullie system. After this she worked on soldering 8 other LEDs with resitances which will be used on the dashboard. After this she helped prototyping the new steering wheel and the kart.
For next time we need to nail the plank to the stands for the dashboard, fixate the LEDs to the dashboard, paint the kart, finish the new steering wheel, relook at the code to add sounds and retest the game.
