So I had several bodge wires on the Rev 1 of the iCamCntrl board. I spun it into Rev 2 that integrated the RTC and backup battery. Unfortunately Rev 2 had an issue sensing one of the buttons! Oops, I had a sneak current path. So a quick spin to Rev 3 which works great. I also changed to a different button that can poke through a 3D printed enclosure and moved the charge LED to under the USB connector.
At the same time I took the opportunity to include a header for the VL53L4CX TOF sensor so it could be both close to the Tiny1C and more easily aligned so it "sees" close to the center of the Tiny1C image.
I use a Qwiic cable to connect to the AHT20 sensor so it can be slightly removed from the camera board to more accurately sense ambient temperature. Ideally in a case it would be isolated from the camera with air flow across it.
Dan Julio
You sir, are a wizard! Excellent project!
Wow, thank you very much.
